Divi WordPress Theme
Wordpress as CMS - Content Management System
Topic: Wordpress as CMS - Content Management System  (Read 5170 times)
Offline HRamesh
  • New Member
    • View Profile
« on: September 21, 2008, 08:20:15 PM »
Hi,
Now a day, Wordpress is also used as a content management system. Have anyone used it as CMS? Are there any plugins available to fully customize wordpress as CMS?
Thanks,
Ramesh
VPS Hosting - AccuWebHosting
Offline Kevin
  • Junior Guru
    • View Profile
Re: Wordpress as CMS - Content Management System
« Reply #1 on: September 28, 2008, 01:40:39 AM »
The first thing you will need is to disply the other page instead of latest post. You can do it using Filosofo Home-Page Control plugin (http://www.ilfilosofo.com/blog/home-pag ... nload_here) and then depending your site, you can install other plugins.
Kevin
Offline HRamesh
  • New Member
    • View Profile
« Reply #2 on: September 28, 2008, 08:47:21 PM »
Hi Kevin,
Thanks for your input.
Ramesh
Offline Kailash
  • Web Hosting Master
  • Administrator
    • View Profile
Re: Wordpress as CMS - cforms for wordpress
« Reply #3 on: September 30, 2008, 10:24:53 AM »
Hi,
I have found one good plugin whcih can help to convert your wordpress blog into CMS. The plugin is cforms and it can be download from http://www.deliciousdays.com/cforms-plugin.
Regards,
Kailash
Shopify Divi WordPress Theme
Tags:
Wordpress 2.7 released with many new features
Started by KailashBoard Forums and Content Management
Last post December 13, 2008, 10:15:09 AM
by Kailash
Wordpress Rating Plugins
Started by AlexBoard Forums and Content Management
Last post August 24, 2011, 08:15:49 PM
by John78
Wordpress Plugin for Search Engine Optimization
Last post January 04, 2009, 11:48:58 AM
by Kailash
curl error after upgrarding to Wordpress 2.7
Started by AlexBoard Script/software installation and upgrade
Last post March 06, 2009, 10:09:13 AM
by Harry
PHPbb3 not working with Wordpress
Started by HarryBoard Script/software installation and upgrade
Last post August 23, 2011, 11:44:11 AM
by Davytoth
