Advantages of Linux Hosting
Started by John23, September 13, 2010, 01:57:05 PM
Hosting Offer
John23
HI,
Since Linux or Unix hosting packages are typically cheaper than Windows based servers, they are normally the choice for many businesses. If you are not familiar with Linux or Unix, there are some points that you will need to keep in mind before you select a Unix based host. There are many advantages to using a Unix based server, which we will detail below.
# Cost : Unix is a free platform, which means that your hosting company will not have to purchase the operating system for your server.
# Scalability : More applications work on a Unix platform and you will have more choices to develop your site in many different directions if you select this type of hosting package.
# Performance : Unix servers work very well, and very quickly. Less system resources are required, which translates into less bandwidth and RAM usage for your site, which can be very helpful.
# Telnet and SSH : If you like having the ability to use Telnet to monitor, run or perform tasks on your server, than Unix is your clear choice. Telnet is not supported on a Windows platform.
smethjain
The advantages of Linux hosting are: Flexibility, Less Downtime, The Low Costs, Provide best Security, Stability and Simplicity.
wadermaxx
Some of the advantages of Linux hosting are It is an open source software product, It can easily be converted into a Windows site, It works well with some of the most popular scripting language, It is more secure than Windows hosting and It also help you to break Microsoft's market monopoly.
bricecooke
Linux is a powerful operating process which has a greater amount of protection & flexibility than options such as Windows when used on servers. Hosting services that offer Linux as an option will often be affordable & versatile in what they can offer to the customers with the hosting.It is also backed up by a wide & active community of open source developers. This means that there's any number of applications, from the most basic to the most technically advanced, that have been created for the process.
annahussy
Linux is one of the best and powerful operating system that really good for use. It provide good quality of security to protect your site. Its very fast, stable, and reliable to host website. It is available in very cheap and reasonable price.
