Divi WordPress Theme
Topic: Check CPU load for a user in CloudLinux  (Read 1694 times)
Offline Chris
  • Junior Guru
    • View Profile
« on: June 21, 2018, 01:53:36 PM »
Hi,
We are using CloudLinux with CageFS. How can we check the CPU usage report for last few hours or 24 hours for a specific user?
Thanks!
Chris
VPS Hosting - AccuWebHosting
Offline Akshay_M
  • Newbie
    • View Profile
Re: Check CPU load for a user in CloudLinux
« Reply #1 on: October 01, 2019, 11:24:35 PM »
Hi,
Thanks!
Chris
You can try using Nagios add-on for monitoring the CPU load and usage.
Regards,
Akshay
Shopify Divi WordPress Theme
Tags:
