Jetpack
Fully Managed WordPress Hosting
lc_banner_leadgen_3
WordPress Hosting Divi WordPress Theme
WPZOOM
Bluehost WordPress Hosting
Recent Topics
How Can I Convert EML to PST Format in Bulk?
Started by mary0550, February 18, 2023, 03:48:58 PM
mary0550
The BitRecover EML Converter is the best software available if you need to convert EML files to PST format. You can use this software to transfer information from EML files to a Microsoft Outlook PST file. Throughout the EML file conversion process, it maintains the file hierarchy just as it was. You can convert a single EML file or a batch of them into PST format with this tool. To test the software's functionality, you can convert up to 25 emails per folder for free with the demo version.
alexjonas
If you need to export EML file to PST Outlook and can't find the best method, then directly install and open BitData Migration EML Converter on PC. This software can easily work on any winOS editions and macOS editions. It has a simple GUI interface to easily convert EML into many other output options i.e. PDF, Office 365, MSG, OLM, MBOX, etc. in batch at one time. For adding the EML files, you can easily use its Select File(s)/Select Folder option as per your requirement. Also allows users to save the resultant output in the preferred location path. It works on all EML based email applications i.e. Entourage, eM Client, MS Outlook, Windows Live Mail, Apple Mail and many more. It also provides the trial version that allows converting first 25 EML files/folder for free.
