Jetpack
Fully Managed WordPress Hosting
lc_banner_leadgen_3
IMAP Backup Tool
Started by Robert Root, April 18, 2025, 04:51:17 PM
Robert Root
One of the best and most effective solutions to export OST to PST is the MacSonik OST to PST Converter, which has simple features that even non-technical users can utilize. This software can convert OST files into multiple file formats such as EML, PDF, MSG, DOC, MBOX, CSV, TXT, etc. It helps you to split the resultant PST file if it is too large and has a huge OST data. Apart from this, the software gives you a date range filter option that allows filter emails based on date.You can convert specific OST emails to PST within a defined date.
AlbertTaylor
Shoviv IMAP Email Backup Tool is a reliable solution to backup emails from IMAP-enabled mailboxes. It allows users to back up their email data into multiple file formats like PST, EML, MSG, and MBOX. With its user-friendly interface, the tool makes it easy to schedule regular backups and apply filters based on date range, folder, and item type. Shoviv ensures data integrity during the backup process, preserving the original structure and properties of emails. It also supports incremental backups, saving time and storage by backing up only new or modified items. Ideal for businesses and individuals alike, it offers efficient and secure email protection.
Read also - Backup IMAP Email
brendybenoite
Yota IMAP Backup Tool is a smart solution to download emails from any IMAP-supported email account. It lets you back up emails to formats like PST, PDF, MBOX, and EML. You just need to enter your login details, and the tool will fetch all emails safely. It also keeps attachments and folder structure intact.
The tool allows you to back up selected folders like Inbox or Sent. You can also use filters to save emails by date or subject. It works on all Windows versions and has a simple interface. Yota IMAP Backup Tool is perfect for safe and easy email backup.
